Sample files won't work, everything up to date
Hey there,
While trying to create variable opacity shading for trees in radiation studies, I loaded up some of the example files.
But “annual_daylight.gh” and “daylight_factor.gh” are not running.
I don’t even have an error message nor anything in the report output.
Command window pops up and goes away quickly after.
Radiance 5.3 installed and latest LB version…
Any idea how is this possible?
Thanks !
edit : The boolean has been turned on True, of course… But simply wasn’t True for the picture only :slight_smile:
I have the same problem. Did you find the solution?
Check this.
https://discourse.ladybug.tools/t/hb-r-annual-daylight/13566
