Schedule not possible for setEPNatVent component
The setEPNatVent component in HB instantiates WindandStackOpenArea object in EP. While WindandStackOpenArea accepts schedules for minimum and maximum indoor air temperature, this is not possible in setEPNatVent.
Do you know a way that I can enter a schedule for setEPNatVent?
When I try to write this field myself manually in the IDF output file, the “Zone Ideal Loads Supply Air Sensible Cooling Energy” variable is not activated in EP anymore. this is my second problem.
thanks!
