Self defined ConstructionSet not working with HB Peak Loads
Hi!
My Problem is as follows.
I am trying to simulate peak loads for a building with a self defined ConstructionSet, but HB Peak Loads keeps displaying different error messages, the latest being “Solution exception: ** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.”. Other simulation components like HB model to OSM seem to be running normally. Do you think my ConstructionSet works as it is supposed to in the OSM-model?
This is what I have tried.
Using the Default Generic Construction Set as a base construction set for the HB Construction Set component, i have added a simple three-layered self defined exterior wall through the HB Exterior Subset component. The HB Construction Set is then connected to my HB Room. As mentioned above, this results in an error.
Just using the Default Generic Construction Set or any of the other pre-defined ConstructionSets seem to be working great.
Any suggestions on this?
This is my grasshopper file.
shoe_box_peak_loads_window_shade_materials_not_working.gh (88.6 KB)
Thank you!
hi @Erling
This is because the “new line” you put into the material name.
Thank you! It seems to be running like a charm now :smile:
