Hello forum.
I need some help with sensitive analysis.
I want to run an energy consumption/lighting analysis of a space. But before running the analysis, I need to confine the weather data to extreme situations in the summertime (instead of the whole year or just defining special days of the year). Could you please guide me on which plugin/component I should use?
You probably are looking for the LB_ImportSTAT
component.
Thank you @AbrahamYezioro what is the cause of the error?
- Solution exception:
Failed to import ladybug:
No module named ladybug.stat
and does EPW have the same component?
You are mixing Legacy and LBT components. Stick with the LBT.
