"Set Exposure Component" doesn't work
Hi I have set up LB and HB on new PC.
The installation is seem to be fine. But, when I run HB, I got problem.
“Set Exposure Component” is not working although HDR2TIFF component can create
image and adjust exposure.
Dose anyone have any idea?
What if you set adjustExposure to False on HDR2TIFF?
It works on HDR2TIFF but it doesn’t on the setExposure component.
Looks like an error with pfilt. It was a bug on Radiance 4.2 for Windows. If you install newer versions of Radiance, that should solve the problem > https://github.com/NREL/Radiance/releases/tag/4.2.2
