setHDRExposure error message
I’m getting the following error message with the HB_setHDRExposure component:
  1. Solution exception:global name ‘HDRFilePath’ is not defined
The HDR file was correctly created with the HB_runDaylightAnalysis. Connecting its output with the HB_HDR > GIF (for instance) works fine.
Can be a bug there?
This was a bug! Fixed and pushed to github. Also attached!
setExposure.gh (15 KB)
