** Severe ** <root>[FenestrationSurface:Detailed]
Hello I got this error using Honeybee transferring over to Open Studio, please help
The simulation has not run correctly because of this severe error:
** Severe ** [FenestrationSurface:Detailed][Sports_Club_1_Srf_0_glz_0_c4f4e13425324cc4b262] - Missing required property ‘construction_name’.
have you any more information about your model setup, an idf file or anything else that can help folk help you?
Based in this error, you should look for the construction for this specific item.
Remember that material and construction are different things in EP.
But if you expect helpful assist, do as @TrevorFedyna said, describing more info, image and file.
