I’m trying to use the shade benefit calculator, but the results are coloring the shades instead of the floor (which is the test region). Any idea of what is wrong?
You are probablyconnecting the wrong geometry to the _testRegion input (The area you want to get the results) with the _testShades one.
Shade benefit studies show you how much harmful sun falling on a test region is blocked by different portions of a shade. Is is possible that you want to just see the number of sunlight hours falling on the test region? In this case, you should run a sunlight hours study
