Hi to all,
I am trying to simulate an atrium space with adiabatic walls and a skylight on top. I have not been able to define correctly de skylight within the HB definition.
Did you have the same issue? if so, How did you fix it?
Thanks
Atrium skylight.gh (22.6 KB)
Hi @Julioamodia89
Here your model works perfectly.
Perhaps something with the units (has to be meters)
I think the units are the problem. You have to set drawing units to meters.
Hi Erik,
It was in meters. It might be the HB version? mine is 1.3.
Hi @Julioamodia89 ,
Mostly this happens when units or tolerances in the rhino document are set differently.
Your 1.3 version works fine on my computer even if I have installed 1.6
