Solar envelope-shell problem
Hi everyone;
I would like to use the “solar envelope” method in the design area which is attached as a Rhino file. The resulting shell didn’t recognize the built environment. How can I solve this problem? I would be very grateful if you help…
Meryem…
solar envelope alan çalışması -2. alternatif.3dm (145.2 KB) solarEnvelopes alan çalışması.gh (412.1 KB)
See attached.
You were using very old components versions + the workflow changed since then.
solarEnvelopes alan çalışması_AY.gh (432.7 KB)
Oh thank you so much Abraham…You’re wonderful :slight_smile:
