Very good question. The current microclimate maps account for some reflected solar but it’s a fairly crude estimation that only accounts for solar radiation reflected off the ground/roof/zone floor towards the occupant (as per the SolarCal method that was recently accepted into ASHRAE-55). So any surface that is above the plane of the occupant currently does not reflect solar to the occupant. Typically, the effect of these above-occupant surfaces is fairly small but it can be very intense in special circumstances (like the walkie talkie building in London that was able to melt cars with it’s parabolic glass facade).
In the microclimate maps, the reflected solar off of the ground is computed by pulling the solar reflectance off of ground materials in the E+ constructions. This get’s multiplied by the occupant’s view factor to the ground (computed in the view factor component) and all of this gets multiplied by the global horizontal solar visible at the occupant location. Global horizontal solar is estimated through sky view (which accounts for diffuse solar) and direct ray-tracing to the sun position (which accounts for direct solar).
If you need to model a case like the walkie talkie building, you can check out this thread:
