Hi, friends,
can you please help me with this error?
I’m trying to recall my information but, first of all, I can’t retrieve any mesh from look up daylighting component. in fact, I sometimes have this problem and usually use original mesh. but now when I’m using original mesh I get this error.
thanks…
Hi farzane,
Probably, the “gradientColor(…) method” of your LB LB is not equals to “gradientColor(…) method” of LB_Recolor Mesh. But I need the file to check.
Could you share a gh file like this?
Best
Antonello
Hi farzane,
I had the same issue. The problem was that I was using an outdated version of Ladybug (VER 0.0.63 AUG_10_2016).
Updating to VER 0.0.63 AUG_25_2016 solved the problem in my case.
Veronika
Dear Antonello
before you respond to my question I removed honeybee and lady bug and installed from the scratch. now I have another issue with recalling annual simulation.
I randomly get this errors
solution exception: index out of range()
: attempted to divide by zero
I attached gh and annual analysis files
I will appreciate if you can help me through…
95-06-21-recall annual analysis.gh (513 KB)
CircularScreen_Depth0.5X.zip (3.45 MB)
Hi Veronika,
In fact, I had an updated plug in. after reinstalling it was solved…
thanks,
Hi farzane,
This issue is because you used “Honeybee_Generate Zone Test Points” with multiple surfaces instead of an honeybee zone. Only the second branch is right, thus if you select it your simulation should be fine.
I suggest that you use “Honeybee_Generate Zone Test Points” with a closed honeybee zone.
Best
Antonello
Dear Antonello
thanks a lot, it was really helpful…
Regards,
Farzane
