Solution exception:invalid literal for float(): Nameplate Pmax + Ladybug Import CEC PhotovoltaicsModule
Hi guys …
I have converted an excel file into .csv extension, downloaded from:
http://www.gosolarcalifornia.ca.gov/equipment/pv_modules.php
Then, used it in the import CEC ladybug component and have the following error:
  1. Solution exception:invalid literal for float(): Nameplate Pmax
Could you pls help me in this regard?
Thanks …
Hi @Ahmed_Jendeya,
Download and use the relevant library from this Github/NREL/SAM/libraries.
Thanks @OmidmRashidi … That works
