I got this warning when opening a gh file working fine previously, and it doesn’t go away even if I updated LB&HB and dragged both of them again into GH.
Any advice on solving this problem without replacing all the components with this warning again and again?
Thanks for the good response, Abraham. To clarify, hitting (ctrl+B) sends whatever components that are selected to the back of the canvass so that GH will read those components first when it opens (or re-computes) the file. You want LB_LB and HB_HB to be read before any other components on the canvass since these components contain all of the libraries and functions that the other components use. When you drop a new LB_LB or HB_HB onto a canvass, it puts the components on the front so you have to select them and hit (ctrl+B) to ensure that everything works correctly in the future.
