[Solved]HB Direct sun hour component went red when timestep greater than 2 (bug, update to the latest version)
Here is the report and the file.
Runtime error (PythonException): The recipe failed to run with the following summary:
Scheduled 24 tasks of which:
  • 7 ran successfully:
    • 1 ConvertWeaToConstant(…)
    • 1 CopyGridInfo(…)
    • 1 CreateOctree(…)
    • 1 CreateRadFolder(…)
    • 1 GenerateSunpath(…)
  • 1 failed:
    • 1 DirectIrradianceCalculation(…)
  • 16 were left pending, among these:
    • 4 were missing external dependencies:
      • 1 DirectSunHoursRaytracing(…)
      • 1 DirectSunHoursRaytracingLoop(…)
      • 1 DirectSunlight(…)
      • 1 DirectSunlightLoop(…)
    • 3 had failed dependencies:
      • 1 CalculateCumulativeHours(…)
      • 1 ConvertToSunHours(…)
      • 1 _DirectSunHoursCalculation_04f49a1bOrchestrator(…)
    • 5 had missing dependencies:
      • 1 LetDirectSunHoursFly(…)
      • 1 MergeCumulativeSunHours(…)
      • 1 MergeDirectSunHours(…)
      • 1 _DirectSunHoursEntryLoop_04f49a1bOrchestrator(…)
      • 1 _Main_04f49a1bOrchestrator(…)
    • 4 was not granted run permission by the scheduler:
Use the report_out attribute of recipe settings to see a full report.
Traceback:
line 91, in script
problem.gh (39.6 KB)
everything went well after I turned off the timestep slide, but when the number was greater than 1 (2 or 3 ) the component went red…
I wanted to gather a line of probes on the surface of a building to save the calculation time in the direct sunhour test, so the grid looks like point line rather than grids
Hi @Zed ,
Thanks for reporting the issue. The issue appears to be linked to your use of the hoys_ input on the “Wea from EPW” component. The timestep works as intended if you apply the analysis_period after the simulation has completed like so:
I’ll see if I can figure out what is going wrong with the hoys_ input when I get the chance.
Digging into the issue further, the issue seems to be with timesteps that aren’t a factor of 2. Everything is fine when I use a timestep of 2, 4, or 8:
I’ll see if I can get to the bottom of the weirdness but it seems related to Radiance not liking factors of anything other than 2.
Ah, nevermind. The bug was on the LBT end but it was just deep on the LBT end. I included a fix as part of this commit:
… and you should be able to get it on your end with the LB Versioner within an hour or so. With the fix, I confirmed that everything is working when the timesteps are a multiple of 3 now:
Thanks for reporting the issue, @Zed !
Thank you, Chris! Things work well now.
