Some issues with butterfly plug-in
I’m just stating with butterfly plug-in (vers 0.0.3) and I have some regular issues in the solution when I try to implement my own design in the indoor_airflow.gh .
I don’t know if I miss something in the input parameters; I change of course the _geo in the createBFGeometry and the _testGeometry in genTestPts and then I launch the script…
But often I receive this king of answer (see pic)
Does anyone know from it comes from?
thx
Forgot the attachement
Did you let the solution to run for enough iterations?
It is a bit difficult to debug this from a screenshot, can you provide a definition?
As Mostapha suggested make sure you let the case run for a while before assessing the results. Additionally, try increasing mesh quality as that Z structure can get ugly really fast on rough meshes (try smth like 0.1-0.2m).
Finally, make sure your probes are inside your mesh, there have been a few instances of values like these when the points were at the border or outside the mesh. To do that scale your input surface on the probe component by 0.9 or smth to make sure the edge of the pressure points are inside the mesh.
Kind regards,
Theodore.
