stackValues option cannot be set as false for barchart when reading data from energy balance component
the data from the energy balance component can be visualized as stacked values using the bar chart:
but if the stackValue option is set as false, the bar chart component will report error:
May I ask if the data from the energy balance component can only be viewed as stacked bar chart?
Thanks!
Grasshope,
You can view the energy balance results in a non-stacked fashion but it’s usually not very pretty:
I noticed that your version of the component is old and I updated it a few days ago. Let me know if you have the same issue in the most recent component.
-Chris
Sorry, Chris, but I’m unable to produce the barchart by connecting the output of the energy balance component to the bar chart component: (demo file attached, and I’ve updated the bar chart component)
Can you kindly advise?
energy_balance_v021.gh (695 KB)
