Strang global radiation graphic
Hello everybody!
I got a strange result from the global radiation analysis.
The dome is with horizontal stripes. It should be an uniform gradient, right?
I attach the image.
Where is the mistake?
Thank you
Marcello.
Hi Marcello, Take a look at this discussion. The reason has been discussed in details.
Thank You Mostapha.
I downloaded the last file you posted in the discussion (Testfile). It works perfectly.
However if I make exactly what is in that file, but with my updated components (the latest version, updated yesterday) it gives me the same error as the beginning.
Then if i open the Testfile and i try to use some other component, i get an error message because, it says, i am using a different version of LB.
I am confused.
I attach here the Testfile, without error, but with old components, and my file (Radiation analysis), with updated components but still with the error.
Please, could you tell me what can I do to have a good result for the diffuse radiation using my updated components?
Thank you.
Regards.
Marcello.
2015.01.25testfiles_updated_.gh (354 KB)
Radiation analysis.gh (375 KB)
