Sun path component is not working
I got the following error message when connecting the location of epw file to the sun path component:
1. Solution exception:‘list’ object has no attribute 'ToNurbsCurve’
Can I have your advices to debug this problem?
Thanks!
sun_path_v001.gh (437 KB)
Grasshope,
You need to update your file and component. See attached.
I left the old one so you can see what has been changed between versions.
Also, if i’m here, i added the recently added LB_GradientLibrary so you can pick from different color schemes (Great Chris’s new addition). See red group at the left.
sun_path_v001_AY.gh (469 KB)
Thank you very much, Abraham!
I shall remember to update LB&HB if a component doesn’t work.
Thank you and Chris for the gradient component which is really handy!
No problem.
Just want to be clear that the gradient component is Chris’s!! I just inserted it in your file, so you get to know it :slight_smile:
Glad to hear that the gradients are making a splash!
Thanks, Chris, as usual!
