Quick question:
Per image attached, what is wrong with the output colors appearance?
I am new (very new —first post) to GH & LB, already in love though…so thank you all for your hard work on these amazing tools!
In more words, for some reason the image generated is producing a textured surface and gradient. Grid is set to 4 (meters) so it should not be the reason, any idea…perhaps something in rhino options I need to change…I am not sure.
Big Thanks!
Hide the Rhino geometry and/or the base geometry in GH.
Abraham Thanks.
I hid the geometry, problem remains.
I does look as if multiple surfaces were plotted…
ugh???
Will continue working on data generation for now, and research meanwhile what the problem here is…
Thanks again!
N—
For sure you are showing at the same time the analysis results and the geometry, either in Rhino or in GH. 100%
Hide the results and you’ll see.
You got it.
Both Rhino+GH, needed to be hidden.
Did not get this in the tutorials.
BIG Thanks!
N—
