Surface reflectance values
From where can i access the interior surface reflectance values that are used as default when carrying out simulation?
You can always use the HB Color Face Attributes component to see the reflectances of the individual surfaces in your model but you’ll find the default Radiance modifiers that are used for different geometry types here in the honeybee-standards repository:
