Mostapha would know more about this issue than I would but I can tell you from the error message that HB is does not seem to be built to read material types that are longer than 4 lines right now. I am sorry that is not so helpful. Is there a reason why you could not model your material with the “Radiance Trans Material”?
I think you are getting an error because your material has ‘strings’ in it. I looked into the Honeybee source code and found this line:
while counter < len(materialProp):<br/> counter += int(materialProp[counter]) + 1
The int(materialProp[counter]) requires that the materialProp[counter] be a number. Simple radiance materials are usually of the format … void plastic box 0 0 5 0.5 0.5 0.5 0.2 0.1 . So everything after the ‘box’ is a number and the code works fine.
If you have a complex materials with terms like ‘grand_dx’ ‘gran_dy’ etc, the Honeybee code will crash as it tries to convert text to numbers. However, I think there should be a workaround. Can you share the gh file for your project ?
I am not sure if you can add a complex material to Honeybee library. However, I might be completely off as I don’t have enough experience with it.
If you are comfortable scripting directly into a rad file and using radiance then you can make it work. I tried some very basic renderings with your material…( I did not change any parameters). See below. The ones with the grainy images are with the texfunc modifier.
