Hello friends
About the bsdf file. How do I know how much light is passing through this material(transmittance light)? Can I change the amount of this transmittance?
Thanks
Hi @Aliarch,
You can use BSDFViewer or the web-based viewer to see the light scattering of each patch of the incident hemisphere.
It is possible to change the scattering data manually in the xml file, however, I don’t think that is advisable. You’re are better off generating a new file.
