The EnergyPlus all output variable not found
I am using honeybee for energy modeling.And I wanted to re-run the idf file.After finished the simulation,there are some per-defined output is not showed in csv file.I also check the eso file and sql file,the two can show the all per-defined output variable. So anyone can tell me why do this happened? And how to fix it?
As the picture showed,the csv file ended with Column IV.
in.csv (77.2 KB)
in.idf (784.4 KB)
Yeah,I have found the solution.The link is https://unmethours.com/question/4156/calling-readvarseso-without-the-255-columns-limit/.
Setting Allow More Than 250 Column is True!!!
255
