Greetings everyone, I got 12 errors when trying to run the Run Energy Simulation component. I got these errors:
- The simulation has not run correctly because of this severe error:
** Severe ** Line: 896 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
** Severe ** ~~~ 15.60675048828125; - The simulation has not run correctly because of this severe error:
** Severe ** Line: 897 Index: 18 - “15.60675048828125” is not a valid Object Type. - The simulation has not run correctly because of this severe error:
** Severe ** Line: 996 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
** Severe ** ~~~ 11.575610160827637; - The simulation has not run correctly because of this severe error:
** Severe ** Line: 997 Index: 19 - “11.575610160827637” is not a valid Object Type.
** Severe ** [json.exception.type_error.302] type must be string, but is null
I’ve tried everything to solve the problem, like checking the scale of the model, installing the older version HB, changing the .ewp file ,but it keeps telling me invalid even I just set a box inside.
It seems the problem was caused by the program after “writeIdf”, does anyone know how to get rid of this? Thank you
HNB.3dm (109.9 KB) Honeybee.gh (561.6 KB)
