I am having a problem with “Therm”.
Although Therm is installed in the proper folder and the files are unblocked I am getting the following eror message.
1. Solution exception:Access to the path ‘C:\Users\Public\LBNL\Settings\therm7.6.ini’ is denied.
I looked at all the files, but they were all unblocked.
I first had two versions of Therm on my computer. 7.6 and 7.7.
Because Honeybee only loaded 7.6 I threw 7.7 away.
The path is correct.
When I try to open the ini file with notepad I get the same message.
