Time with minutes
Hello Mostapha,
probably a simple thing. What’t the way to use minutes in the Ladybug Sunpath and Analysis Period components? Thank you.
Francesco
Hi Francesco,
In case you are using hour, day and month, use a float number for hour (e.g. 6.5 = 6:30).
If you are using analysis period to generate the sun positions then change the timestep.
-Mostapha
Hi Moustafa,
It is working when using hour, day and month.
but is not working when using analysis period component
What’t the way to use minutes in the analysis period component?
Thanks
Khaoula
Hi Khaoula, Can you tell me what are you trying to achieve? Why do you need to use analysis period in this case?
I need to calculate solar radiation from 5h to 19h40
The image I posted was just for testing
Thanks
Hi Khaoula, You need to use radiation analysis component for that and then generate the sky for 5-20. The timestep for sky is hourly.
