Tips for self trouble shooting of HB daylight analysis
Hi everyone,
Can anyone give me some tips how to troubleshoot a daylight analysis model. I have modeled a simple one HB zone with custom openings on a three facades by using add openings component. One of the facade openings doesn’t returning the expected results.
Here are the things I have checked so far,
  • the openings and the HB surface are co planer
  • the normal vectors of the openings are the same ( not sure it matters in HB daylight analysis)
  • I set the RD material for openings HB surfaces as in the sample file here
  • I also tried any individual opening on this surface and the visualization looks expected, while I added the multiple openings at the same HB surface the visualization looks odd!
PS. I use Santiago Chile weather data for this sample file but it doesn’t matter if u input another weather data in case u want to look I attached the files.
Thank you in advance
A06 - LEVEL 6.3dm (1.01 MB)
Parametric_Daylight_Analysis - 1.gh (539 KB)
Hi Elcin,
To generate acceptable Windows (FOR ENERGYPLUS AND HB glazing creator components) it is required to set a minimum distance from the edge of surfaces.
Please find attached.
OMD.
Parametric_Daylight_Analysis1_OMD.gh (565 KB)
Thank you very much Omid for the very prompt reply. You rock!
-e
