Topography in Ladybug
Hi Mostapha,
I’m currently attempting to make a Sunlight Hours Study across a topography model using Ladybug. For some reason it is coming up as the entire model as 0 hours of daylight, even when I put in the summer solstice. Any idea what I’m doing wrong? Is the daylight hours study only usable with building models and not topography?
-Ben
Hi Ben,
Check the normal direction of the test surfaces. I assume they are downward in your model.
Mostapha
PS: I’m still not ready to release the new version officially but as I assume you may have so many test points for your study feel free to download the newer version from this link and replace it with what you already have: (https://dl.dropboxusercontent.com/u/16228160/Ladybug_0.0.46_WIP.zip). Set the parallel to True and if you are running the study on a system with multiple cores the study will run times faster.
PS1: Anybody else who is willing to try the new version is also welcome to do so. Just download it from the same link. I will release the new version 0.0.49 pretty soon. There are minor modifications to be made before the release.
