Total Radiation component baking for AI fails to bake Direct Radiation
Hello forum,
Here is what I found, typically Total Radiation component shows 3 types of diagram: total, diffuse and direct radiation diagrams (which are not the same size and this is a minor problem). I want to use them all in my presentation but I also want to tweak their size and some text, so I go and bake it for AI. For some reason component bakes only 2 diagram and returns error:
  1. Solution exception:index out of range: 0
As you can see direct radiation wan not baked, please check the component or let me know if I screwed something up.
I updated LB the day before yesterday.
CHN_Shanghai.Shanghai.583620_CSWD.epw (1.69 MB)
02_Radiation.gh (474 KB)
Tim,
I can’t seem to replicate the error.
Am I using your file correctly?
-Chris
Hey Chris,
Try to generate only for January. I just ran analysis for one month and it failed again.
Edit: February fails too as well as October, November and December, but March, April and May are ok… Weird. Others I didn’t check.
