Hello together,
I have a problem with the HBContext input. I would like to use a schedule generated by the csvSchedule component as EPTransSchedule for the EPContextsrf.
Without assigning a schedule, the simulation works fine and takes 10-15 minutes. But assigning a schedule the simulation process seems to freeze/pause at the point displayed in the screenshot attached. Did anybody here face similar problems?
Cheers,
/Tobi
I think this was an issue with E+ itself, that was failing to show the simulation progress when using .csv schedules. If you leave it running, it should be fine.
It got fixed in E+9.0 onwards, although there are some compatibility problems for Window shading objects between both versions.
Thanks for your answer @RafaelA!
Unfortunately, I don’t think that it’s a problem of the E+ version. I am using several csv-schedules and none of them causes similar problems…
I left it running for around 45 minutes and nothing happened/the simulation didn’t finish. And as I told you before, without this particular schedule the simulation is terminating after approx. 10 min.
Anyway, I don’t think that only by assigning a schedule the total simulation time is increasing that much.
Cheers,
/Tobi
I see, I had somehow assumed it was related to this issue of E+ 8.9.
When there is a transparency schedule applied to a context surface E+ will automatically change the default algorithm to calculate Diffuse radiation from SimpleSkyDiffuseModelling to DetailedSkyDiffuseModelling. I don´t know if this could be the reason behind the longer simulation time.
Have you tested using another type of schedule for the Transparency of EPContextsrf?
Hello @RafaelA,
Yes, I have tested another type of Schedule, but the problem is the same.
After reading your answer I guess that it really could be the more accurate algorithm that causes the long simulation time. I will have another run without interrupting, maybe it just takes some time. I’ll keep you posted.
Thanks for your help!
Cheers,
/Tobi
