Hi everyone,
I am trying to add a schedule to tree (for leaves) and I try to use the same as Chris used in the tutorials but when I am using the same idea the energy simulation stops at the beginning and does nothing. Can you tell mw what could be the solution or other way to adjust the schedule of the leaves?
Thank you!
tree_sch.gh (628.2 KB)
@Saboakos The connection in your file has a bug. You should connect schedule name to EPTransSchedule.Then energy simulation will be normaly running.
tree_sch-fix.gh (620.3 KB)
Hi @minggangyin, Thank you for your answer. You could be right but for now the “Honeybee EP context Surfaces” says that it cannot find the Treeleaves in Honeybee schedule library. But I see in your picture you have it.
@Saboakos There are another solution for your schedule. You can use seasonal schedule for the tree leaf.
tree_sch-fix2.gh (656.6 KB)
@minggangyin Ah nice. Thank you so much for your effort @minggangyin. Thank you !
