Hi All,
I have a problem that i don’t know how to solve.
blockmesh error code :
"Runtime error (EncoderFallbackException): ‘ascii’ codec can’t encode character ‘\u142’ in position 110: ordinal not in range(128)
Traceback:
line 206, in _run_ironpython, “C:\Users\Paweł\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\runmanager_bluecfd.py”
line 234, in run, “C:\Users\Paweł\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\runmanager_bluecfd.py”
line 756, in command, “C:\Users\Paweł\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\case.py”
line 788, in blockMesh, “C:\Users\Paweł\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\case.py”
line 52, in script"
As you see my username has a unicode character, that isn’t supported by the script. What am I supposed to do? Is it possible to change butterfly directory?
Best
P
