Hello community,
I am fairly new to GH and Butterfly, and any help or input is much appreciated!
I’m trying to perform a shape optimization using Butterfly in GH. The goal is to change the shape to minimize the drag coefficient. Here is a snapshot:
This is before the solution is run (not converged yet). As you can see, the values for drag and lift in the right panels get calculated regardless of whether the solution has run or not. However, the initial values are wrong, and will ruin the optimization results. I need to find a way to only plug the final values into opossum, after the solution has converged.
Any ideas how that could be done?
TYIA
