URGENT. Materials and Thermal energy
Hi everybody,
I’m doing a project about optimizing a house and I did some simulations in order to set the optimum glaze ratio and orientations of the house in order to have the minimum energy consumption (heating+light). Now I was trying to see how the construction materials have influence on those outputs, and I was wondering what is the pre-set material of a Madrise Apartement Zone, because when I put some isolation materials as walls, then the heating consumption increases instead of decreasing. Here I upload the file.
Modelisation house optimisation.gh (1.77 MB)
Hi Axel, Default construction doesn’t change based on program. Here is the list of the default construction and you can use deconstruct construction and then deconstruct material to see the details.
deconstruct_construction.gh (431 KB)
Thank you so much!
