The attached image shows the output files of an annual daylight simulation via HB legacy, which uses the DC method for the definition of solar positions.
Is there a way to run an HB[+] annual simulation (anallema solar positions) for the same scene/points, without having to remodel everything in Grasshopper?
Basically is there a way to import/feed the necessary files (geometries/materials) to the HB[+] engine and only generate the sky to run the simulation?
