useOldRes_ in the genCumulativeSkyMtx component doesn't read sky mtx file already created
I generated the sky mtx file in the first step:
but the useOldRes_ input node doesn’t read the sky matrix file already created once it’s set as true:
May I ask if I miss anything here?
THank you!
Grasshope,
May i ask you how do you know it is not reading it?
From your second image you need to set the runIt to True. Otherwise it won’t do anything.
