Hi
I have been trying to create an EP window material but it shows the following error
- Can’t find LOW-EPS in EP Construction Library.
Add the construction to the library and try again.
As suggested by Mostapha, I went through the following WISH: Creating and Adding new Schedules to the EP Library - Grasshopper
I also tried using a custom window material - “Fixed window”
However, the error is 1. Can’t find FIXED WINDOW 3.81/0.39/0.27 in EP Construction Library.
It seems that my userCustomEPLibrary is all Blank. Please share the complete idf file and an example of how do I add the required window material to it (in terms of U- Value, and SHGC)
