hi @chris
Speaking of Grid_filters with a lbt recipe, I’ve been trying to simulate different grids not all at once while aggregating results in the same case folder.
Say from the list of grids (0, 1 , 2,…)
Simulate first grids 0 and 1
Then simulate the other one
Aggregate all results in the same case.
So far when reload_old is set to true, changing the grid_filter doesn’t launch the new run.
If reload_old is set to false, changing the grid_filter erases previous runs.
In the case of large number of grids, this feature would allow to post process results of a portion of the completed grids and one could pursue his/her workflow while the rest of the grids are running.
Kind regards,
