UTC Map on MAC with M! processor - ERROR: radiance 'silent'
I am running Ladybug in Rhino 7 on an M1 MAC.
I get the following error from the UTCMAP component in the example outdorr_comfort_under_a_tree.gh
Runtime error (TypeErrorException): run() got an unexpected keyword argument ‘silent’
Traceback:
line 155, in script
I installed both Radiance and OpenStudio as recommended.
Any idea what I could do?
It looks like your installation of the Ladybug Tools core libraries is old for the version of the components you are using. You should run the LB Sync Grasshopper File component to make sure the versions of the components on your canvas are aligned with the version of Ladybug Tools that you have installed.
Ok, so now the UTCMAP give the following error.
Runtime error (ValueErrorException): Input “schedule” was not found for recipe “utci_comfort_map”.
Traceback:
line 141, in input_value_by_name, “/Users/Bastian/Library/Application Support/McNeel/Rhinoceros/7.0/scripts/lbt_recipes/recipe.py”
line 182, in script
Compared to all other components that are 1.4.0 the UTCMAP says 1.4.4. Is this correct?
It’s still the same issue, @bastiann . Your UTCI Map component should be 1.4.0 if you want to use it with the version of the core libraries that you currently have installed.
