I am doing the view study based on LBT 1.5.0, but it seemed weird that the study shows 100% view. Any ideas?
Views_for_LEED_v3_and_v4_and_GS_V1.5.0.gh (603.8 KB)
You are not plugging in a reasonable input for _view_points
. These are supposed to be the points which you are wondering whether they can be seen by the input _geometry
. Not the points on the geometry itself.
Maybe you want to run the LB View Percent component instead of the LB Visibility Percent.
Hi @chris,
THank you for your reply. Actually, I would like to plot something like this. I think the view points should be right since they meshing the points on the working plane.
View_to_the_Outdoors_Through_a_Facade (hydrashare.github.io)
thank you it works now
