Visualize EnergyPlus results with Honeybee
Very impressed with the latest Honeybee release. I’m attempting to use Honeybee to visualize surface temperature data from pre-existing EnergyPlus models. I thought I had a handle on this from watching Chris’s (very informative) videos, but keep receiving an error.
I’ve run the EnergyPlus models separately, and outputted the surface data, and surface temperature data in those models. My idea was to use the “import_idf” function to get the honeybee zones, and “read_ep_surface_results” for the temperature data. When connecting these items to the “color_surfaces_by_ep_results”, i get the following
error: 1. Solution exception:unsupported operand type(s) for -: ‘str’ and 'int’
Any advice as to where this error comes from? or if this technique will even accomplish what I hope?
Stefan
ImportIDF_viewTemperatures.gh (137 KB)
Hi Stefan,
Can you also update, idf and csv files so we can reproduce what you have up there?
Mostapha
Hey Mostapha! Good to hear from you.
Sorry, I think there was an issue with my .idf file that I managed to fix after making a new one from scratch and the error went away. My apologies for prematurely posting up here. I’ll close the discussion.
Stefan
