Is there a way to adjust the fan efficiencies and pressures of the VRF terminals? There does not seem to be a way to modify them from the object parameters component attached to the VRF terminal component and the 300 pa default that I am seeing in Open Studio seems rather high.
Hi @Elliot_Glassman, please use VRFTerminal_Adv instead, so that you can set all parameters of each child object.
Ah, so simple! Thanks, Mingbo!
