When using the Wallacei plugin to calculate the Standard Effective Temperature (SET) and Useful Daylight Illuminance (UDI 100-2000) in architecture, I set absolute values in the process, but the SET fitness value turned out to be negative. Is the fitness value the result?
In this link,
someone mentioned flattening the data, but even after flattening the data for UDI, the results are still strange numbers.
