Does anynone know, why I get this warning, while my daylight simulation is running?
Because your Honeybee geometry isn’t perfectly planar. Are you creating your honeybee objects from meshes? If so, the latest development version of the LBT plugin that you can get with the “LB Versioner” has some enhancements that will improve the planarization upon export.
