Which output component can see the value of “chiller(electricity)”?
hello friends,
use “runenergy simulation”component we can see different output value like cooling,temperature and so on ,but i can‘t find which component can see the value of “chiller(electricity)”.
and i’m confused about how to set the air condition worktime in monday to friday,9:00~12:00 & 14:00~18:00. can anybody help me?
thanks,
sherly
Sherly,
If you need outputs of electricity and fuel, you should be modeling a real HVAC system with the OpenStudio component (instead of the default ideal air loads with the energy simulation component) as you see in this example:
If you use a real HVAC the cooling and heating outputs of the Read EP Result component will be electricity and fuel.
-Chris
