Why fault "attempted to divide by zero"?
Would you tell me why there is a fault “attempted to divide by zero”? Thank you very much.
Please reduce the grid size and check. If the error still reflects, then disconnect the analysis period component and check.
Otherwise, internalize the geometry and share the workflow.
