Hi, Why isn’t it possible to define sky illuminance for the daylight factor in Honeybee+? The DF is technically dividing the available illuminance inside to the illuminance outside.
Honeybee takes care of assigning the default value and dividing the results internally. The no need for a user to Sen the number.
@mostapha thank you very much. Although the metric is a little bit outdated and biased, it would be good feature if we could have the input set manually as well.
Thank you very much.
