Hi All!
Firstly, YAY I’m glad this component has arrived! Removes the annoying spagehti mess of the native components.
However, I am curious as to why it has been coded to extrude the windows INSIDE the model. Typically these are extruded outside. The reason why I ask is because in daylighting analysis, these extrusions cause some shading under them which is not accurate.
