Xform.exe + gendalit.exe has stopped working
Hi guys,
I need advice about Honeybee, I got this error when running daylight simulation in Hydra example file
  1. Solution exception:Failed to read the results!
rtrace: fatal - (unnamed_RAD.oct): truncated octree
The snapshot attached, any help?
Hi Yasser,
Can you attach your gh file as well ?
Sarith
Hi Sarith,
I use the example file from hydrashare.github
http://hydrashare.github.io/hydra/viewer?owner=mostaphaRoudsari&amp…;
any advice?
Thanks
Hi Yasser,
I checked that file on 32bit and 64bit modes on my system and everything works out fine. Did you change/add any inputs from that file? Truncated octrees usually result from errors in how geometry/models are defined.
If you did change the file, can you post your gh file as well?
Sarith
